I have a polygon layer that I do editing and reshaping to and I've been having an issue where there are way too many vertices in my layer. I started with a linear layer and ran simplify tool at Muel Wang 1 meter, which is standard for our methods, and I've never had this problem before. I ran the error inspector and had almost 3000 errors. I fixed all of them, but there are still too many vertices with gaps it seems. I tried creating a new gdb and new feature dataset and copying my working layer over and then creating a whole new topology, but the vertices issue still persists. Reshaping has been an issue since there are so many vertices it fails most of the time, so the only way around that is to use the split tool to delete then merge if I need to reshape. Has anyone else come across an issue like this?? I updated to 3.2.1 right before this I believe. Any help is appreciated!
