Hi Community.
I would like to know if someone can help me with this.
I have 3 different layers, all polygons.
- Roads
- Landuse
- Drainages
These polygons has tables with data.
I want the software to look for areas where there are similarities between the three layers based on attributes inside the datatable. For example:
An area will have landuse "Residential" with Drainages "5 meters width" and with road type "highway"
Other area may have landuse "recreational" with drainages " 10 meters width" and road type "secondary road"
Words between "" is data comming from the attribute table.
The importan thing is I want the software look for this areas comming from the attribute table data, then being represented as a common area, or homogeneous zone. Or areas the same info within.
