I am using Trace Networks in Pro as a replacement for Geometric Networks in ArcMap. With Geometric Networks, an attribute field called "Enabled" made it possible to individually "turn on/off" features, a.k.a. enable or disable flow through that feature. Is this possible with Trace Networks?
I can't find any info on this--every search yields posts on Enabling/Disabling Topology for a Trace Network, which I also don't really understand. The documentation for Trace Networks is pretty bad, and documentation comparing Trace Networks to the legacy Geometric Networks is even worse.
This is kind of frustrating because the "Enabled" attribute field was a really easy way to see what I had "turned on/off" in my network. Is there anything comparable for Trace Networks?
