Hi all,
I've been encountering an issue preventing me from creating an X-Y Point features from an imported .xlsx table.
Using ArcGIS Pro 3.2.1 I've imported a .xlsx file as a standalone table into my project and am able to successfully open it and confirm that all the expected is there.
My problem has arisen when I attempt to create points from the table using the "XY to Point" geoprocessing tool. The Geoprocessing tab on the right side of the project window only seems to recognize one column from my table (AutoNumberID) and none of the other fields.
*Note: The coordinate system shown in the Geoprocessing tab (GCS_WGS_1984) is simply the default. I normally switch it to the project's PCS (NAD 1983 UTM Zone 10N) but didn't go back and retake the screen capture.
I've tried converting the table to .csv files and uploading those and creating new, abbreviated, tables with only the two Northing and Easting columns, but I encounter the same problem.
Frankly, at this point, I'm pretty stumped.
Any thoughts or suggestions?
