In ArcGIS Pro where I am using the standard, out-of-the-box "World Imagery" basemap, I am using the "Esri 2020 Land Cover" layer from Living Atlas (and quite a few others as well). When running Analyze to share my map, I get the error:
"Service layer has a different projection than the map's projection"
and "Esri 2020 Land Cover" is noted. The PCS of my basemap is WGS 1984 Web Mercator (Auxiliary sphere). I know the above error indicates that the cache service layer ("Esri 2020 Land Cover") has a different projection than the map being shared, and the doc for "Esri 2020 Land Cover" says the data projection used is UTM.
How can I go about correction this issue w/ "Esri 2020 Land Cover"? I do not want to change to PCS of all my other layers and the basemap just to fix the issue w/ this one layer.
