Hi everyone,
I am currently on my ArcGIS Pro 3.2.0 trial version and I am testing some potential use cases for my company. One of these is that we are able to connect with ArcGIS Pro on to our Microsoft SQL Server 2019, which we use on a regular basis.
When I try to establish a connection to the database in the catalog pane I am getting following error: Connection was attempted with an older version of SQL Server client communications software that is not supported. []
The used connection properties should be right and I asked our IT department to install the newest ODBC 18 Version onto our SQL Server, but I am still not able to establish a connection to the server. What could be the reason for this error.
For further information we are able to connect to the server using QGIS and MapInfo, but ArcGIS Pro won´t work.
Thank you for your help in advance!
