ArcGIS Pro 3.1.2; mobile geodatabase
I have tables called TEST_TABLE and TEST_TABLE_2 in the same GDB.
If I accidentally try to rename TEST_TABLE_2 to TEST_TABLE, then I get an error, as expected, since we can't have two objects with the same name. The table does not get renamed.
However, on closer inspection, when I try to rename the table again, the selected rename text (for lack of a better term) gets displayed as TEST_TABLE, not as TEST_TABLE_2. It's as if TEST_TABLE_2 is actually named TEST_TABLE somewhere behind the scenes.
It's hard to explain, so I'll show it in a video:
Why is that happening?
Thanks.
