I'm currently testing ArcGIS Pro 2.9.8 and 2.9.10 with Utility Network 3 (Electrical) on ArcGIS Enterprise 10.8.1 and have come across an issue that we haven't seen in ArcGIS Pro 2.7.4 before.
Our model has an Electric Assembly that can contain Electric Devices via containment association.
When an electric assembly's geometry is modified (eg. Z value) all of the associated electric device features that are contained are also moved even with the 'Disconnect' option enabled.
There is a before & after image attached. From the after image, see can see all the dirty areas created by the change. The device features are all at the location of the assembly (highlighted feature) and the network is now broken by these moves.
Has anybody else noticed this before and maybe know of a solution (eg. wrong option configured) or is this bug?
This only occurs with point features that have an association either containment or attachment and can be the same domain or across domains (eg. structure to electric, electric to electric, structure to electric)
Thanks for any help with this.
