Hi Gregg - I was actually able to get this to work. My xml looks exactly like yours above, only I am stopping at scale 282:
<?xml version="1.0" encoding="utf-8" ?>
<CacheInfo xsi:type='typens:CacheInfo'
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xmlns:xs='http://www.w3.org/2001/XMLSchema'
xmlns:typens='http://www.esri.com/schemas/ArcGIS/1.4.0'>
<TileCacheInfo xsi:type='typens:TileCacheInfo'>
<SpatialReference xsi:type='typens:ProjectedCoordinateSystem'>
<WKT>PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",3857]]</WKT>
<XOrigin>-20037700</XOrigin>
<YOrigin>-30241100</YOrigin>
<XYScale>10000</XYScale>
<ZOrigin>-100000</ZOrigin>
<ZScale>10000</ZScale>
<MOrigin>-100000</MOrigin>
<MScale>10000</MScale>
<XYTolerance>0.001</XYTolerance>
<ZTolerance>0.001</ZTolerance>
<MTolerance>0.001</MTolerance>
<HighPrecision>true</HighPrecision>
<WKID>102100</WKID>
<LatestWKID>3857</LatestWKID>
</SpatialReference>
<TileOrigin xsi:type='typens:PointN'>
<X>-20037508.342787001</X>
<Y>20037508.342787001</Y>
</TileOrigin>
<TileCols>512</TileCols>
<TileRows>512</TileRows>
<DPI>96</DPI>
<LODInfos xsi:type='typens:ArrayOfLODInfo'>
<LODInfo xsi:type='typens:LODInfo'>
<LevelID>0</LevelID>
<Scale>295829355.45453244</Scale>
<Resolution>78271.516964011724</Resolution>
</LODInfo>
<LevelID>1</LevelID>
<Scale>147914677.72726622</Scale>
<Resolution>39135.758482005862</Resolution>
</LODInfo>
<LevelID>2</LevelID>
<Scale>73957338.863633111</Scale>
<Resolution>19567.879241002931</Resolution>
</LODInfo>
<LevelID>3</LevelID>
<Scale>36978669.431816556</Scale>
<Resolution>9783.9396205014655</Resolution>
</LODInfo>
<LevelID>4</LevelID>
<Scale>18489334.715908278</Scale>
<Resolution>4891.9698102507327</Resolution>
</LODInfo>
<LevelID>5</LevelID>
<Scale>9244667.3579541389</Scale>
<Resolution>2445.9849051253664</Resolution>
</LODInfo>
<LevelID>6</LevelID>
<Scale>4622333.6789770694</Scale>
<Resolution>1222.9924525626832</Resolution>
</LODInfo>
<LevelID>7</LevelID>
<Scale>2311166.8394885347</Scale>
<Resolution>611.49622628134159</Resolution>
</LODInfo>
<LevelID>8</LevelID>
<Scale>1155583.4197442674</Scale>
<Resolution>305.7481131406708</Resolution>
</LODInfo>
<LevelID>9</LevelID>
<Scale>577791.70987213368</Scale>
<Resolution>152.8740565703354</Resolution>
</LODInfo>
<LevelID>10</LevelID>
<Scale>288895.85493606684</Scale>
<Resolution>76.437028285167699</Resolution>
</LODInfo>
<LevelID>11</LevelID>
<Scale>144447.92746803342</Scale>
<Resolution>38.218514142583849</Resolution>
</LODInfo>
<LevelID>12</LevelID>
<Scale>72223.96373401671</Scale>
<Resolution>19.109257071291925</Resolution>
</LODInfo>
<LevelID>13</LevelID>
<Scale>36111.981867008355</Scale>
<Resolution>9.5546285356459624</Resolution>
</LODInfo>
<LevelID>14</LevelID>
<Scale>18055.990933504178</Scale>
<Resolution>4.7773142678229812</Resolution>
</LODInfo>
<LevelID>15</LevelID>
<Scale>9027.9954667520888</Scale>
<Resolution>2.3886571339114906</Resolution>
</LODInfo>
<LevelID>16</LevelID>
<Scale>4513.9977333760444</Scale>
<Resolution>1.1943285669557453</Resolution>
</LODInfo>
<LevelID>17</LevelID>
<Scale>2256.9988666880222</Scale>
<Resolution>0.59716428347787265</Resolution>
</LODInfo>
<LevelID>18</LevelID>
<Scale>1128.4994333440111</Scale>
<Resolution>0.29858214173893632</Resolution>
</LODInfo>
<LevelID>19</LevelID>
<Scale>564.24971667200555</Scale>
<Resolution>0.14929107086946816</Resolution>
</LODInfo>
<LevelID>20</LevelID>
<Scale>282.124858336002775</Scale>
<Resolution>0.07464553543473408</Resolution>
</LODInfo>
</LODInfos>
<PreciseDPI>96</PreciseDPI>
</TileCacheInfo>
<TileImageInfo xsi:type='typens:TileImageInfo'>
<CacheTileFormat>PNG</CacheTileFormat>
<CompressionQuality>0</CompressionQuality>
<Antialiasing>false</Antialiasing>
<BandCount>1</BandCount>
<LERCError>0</LERCError>
</TileImageInfo>
<CacheStorageInfo xsi:type='typens:CacheStorageInfo'>
<StorageFormat>esriMapCacheStorageModeCompact</StorageFormat>
<PacketSize>128</PacketSize>
</CacheStorageInfo>
</CacheInfo>
I got this to work once but can't repeat it, run fails. I'm just trying to create a simple street overlay for our imagery reference basemap and can't.
After following all the guildelines for authoring a multi-scale map for authoring vector tiles, I still get really poor draws: Large areas of simple linework at medium scales like 1:72K, 1:36K will not render when panning and/or won't label when they do draw.
If anyone has any idea on what keeps large tiled areas from drawing I would appreciate any insight. But it may not matter until ESRI resolves this tiling scheme issue
