What is wrong with my tables format?
685
07-20-2021 08:59 AM
JustinSmith
New Contributor II
Currently using Pro 2.7.0.  Recently had some external changes where I remote in to my desktop at the office through either a VPN or Citrix and I definitely noticed non-ESRI issues with these changes.  Curious if this is linked in some way so I wanted to double check.
See attached image!
Thanks!
George_Thompson
Esri Frequent Contributor
That looks like a display issue, not a "table" issue. If you are remoting into your PC in your office, it could be how the data view is being rendered on your side.
--- George T.
JustinSmith
New Contributor II
Okay, thanks.  I was sort of afraid that would be the case.
George_Thompson
Does the data look the same in a file geodatabase vs. Enterprise Geodatabase (if you have one) on terms of the table?
There may be some settings for the display technology that may "improve" the issue. I am not sure of specific ones.
--- George T.
JustinSmith
New Contributor II
Looks like same issue - only in Pro too.  Catalog and ArcMap are fine.  Also noticed this in attached image.  Looks like pre-populated field is the issue.
George_Thompson
May want to check and change the settings for the display: https://pro.arcgis.com/en/pro-app/latest/help/mapping/properties/display-options.htm on the ArcGIS Pro machine. I would review the following sections: Rendering quality, Rendering engine, Hardware antialiasing, Performance tips for virtual environments
--- George T.
