Why are my fields with domains showing the code not the description value in Pro?
1886
07-12-2016 04:26 PM
AlixBakke_SNC
I opened a feature class in Pro, and my fields seem like they have domains applied; however, the code not the description value of the domain is showing up. And, if I attempt to edit the value in the respective field in the attribute table, it's as if the coded domain value does not exist.
I attempted to assign the domain value and that didn't work. I tried to create a new domain and then assign, that also failed. Any suggestions? I'm trying to migrate to Pro from 10.4, but I'm stuck on this one.
Thanks for any feedback,
Liz
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
I hope you have used Integer (Short/Long) as the datatype of the corresponding field in the attribute table.
Think Location
AlixBakke_SNC
Yes, this is the case.
