Joining a table is easy. In ArcGIS Pro, you simply right-click a table, goto "Join and Relate" and then select "Add Join". This takes you to a Geoprocessing tool where you select the input join field and output join field and voila, your table is joined !
1. But, when it comes to using the "management.AddJoin" with ExecuteToolAsync(), you actually end up with a new table with the two tables joined together:
2. Then, if you want to recalculate a field in the input table, you would have used the following python code:
and expect to use the following code in C#:
But, this won't work. You actually have to reference the original input table that you had "wished to join" in as the input table's name:
