ActivePortalChangedEvent is not fired after change teh active portal
383
12-11-2017 04:13 AM
GISMountains
Hello
ArcGIS Pro SDK question: an addin needs to know if the user change the portal which is active. for this purpose it looks that there is an event:
ArcGIS.Desktop.Core.Events.ActivePortalChangedEvent. But it is not fired.
I used the Snippet from https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-Sharing
ArcGIS.Desktop.Core.Events.ActivePortalChangedEvent.Subscribe((args) => {    var active_uri = args.ActivePortal?.PortalUri.ToString();   //etc});
And subscribed the event after Event "ArcGIS.Desktop.Framework.Events.ApplicationStartupEvent" in the initialize-function like it is described in the chapter "Subscribing to Application Events": ProConcepts Configurations · Esri/arcgis-pro-sdk Wiki · GitHub
other events like ProjectClosedEvent, ProjectOpenedEvent, ProjectSavedEvent, ProjectItemsChangedEvent works fine.
But the events ActivePortalChangedEvent, ArcGISPortalAddedEvent, ArcGISPortalRemovedEvent do not work as i expect. Do I understand something wrong?
Thanks in advance
UmaHarano
Hi
Your code looks correct. I was able to reproduce the problem.  This has been fixed in 2.1.
Thank you!
Uma
UmaHarano
Hi
Thank you!
Uma
