Angle between two points
7615
08-25-2015 07:06 AM
mikeharol1
New Contributor II
What is best way to determine angle between two mappoints?
ThomasEmge
There are probably a number of approaches. I suggest using a LineBuilder to create a LineSegment using the two points as the start and the end point. The created segment in return contains an angle property.
https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic7741.html
ThomasEmge
JoeBorgione
Alternatively, you may take a look at the Near Tool as well as the Generate Near Table Tool. Each allow you to generate the angle.
That should just about do it....
mikeharol1
New Contributor II
so i think like the linesegment approach but it returns the angle relative to x axis going counter clockwise as opposed to the preferable gis coordinate system starting at y axis in a clockwise direction.  so if the lineSegment.angle returns 30 degrees that would actually be 60 degrees on the compass.   Is there a method or technique to make the conversion?
mikeharol1
New Contributor II
this seems to work for me thanks for help
double Rad2Degrees = 180 / Math.PI;
var lineBuilder = new LineBuilder(p1, p2);
var lineSeg = lineBuilder.ToSegment();
var degrees = lineSeg.Angle * Rad2Degrees;
degrees = 90 - degrees;
if (degrees < 0)
    degrees = degrees + 360;
