Capture geoprocessor progress and messages from Pro Net SDK
251
01-24-2023 10:57 PM
LewisTrotter
I have a python toolbox that has a tool in it that I want to run from the Pro Net side. Easy to do. However, I was wondering if it is possible to pass the geoprocessors messages and progressor values out of the geoprocessor into Net as the geoprocessor runs. Is this possible?
Basically, I'm trying to create an improved dockpanel UI for the geoprocessor, but I need to do the processing on the python toolbox side.
Thanks!
GKmieliauskas
You could use the code from Esri community samples:
        private async Task<bool> ExecuteDeleteFieldTool(BasicFeatureLayer theLayer, string fieldName)
            try
                return await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
                    var inTable = theLayer.Name;
                    var table = theLayer.GetTable();
                    var dataStore = table.GetDatastore();
                    var workspaceNameDef = dataStore.GetConnectionString();
                    var workspaceName = workspaceNameDef.Split('=')[1];
                    var fullSpec = System.IO.Path.Combine(workspaceName, inTable);
                    System.Diagnostics.Debug.WriteLine($@"Delete {fieldName} from {fullSpec}");
                    var parameters = Geoprocessing.MakeValueArray(fullSpec, fieldName);
                    var cts = new CancellationTokenSource();
                    var results = Geoprocessing.ExecuteToolAsync("management.DeleteField", parameters, null, cts.Token,
                        (eventName, o) =>
                            System.Diagnostics.Debug.WriteLine($@"GP event: {eventName}");
                            if (eventName == "OnMessage")
                                System.Diagnostics.Debug.WriteLine($@"Msg: {o}");
                    return true;
            catch (Exception ex)
                MessageBox.Show(ex.ToString());
                return false;
Write specific messages from your python code and you get content of message in event "OnMessage".
Parse message content for specific type.
For example, for progressor message could start with prefix "Progressor:". All message text could look like this "Progressor: 1". It will mean that progressor value must be equal to 1.
arcpy.AddMessage("Progressor: 1")
P.s. There is "OnProgressMessage" and "OnProgressPos" messages too which you can use directly. Try to investigate in arcpy library.
Solved: How to get return value from python tool - Esri Community
SetProgressor—ArcGIS Pro | Documentation
GKmieliauskas
            try
                        (eventName, o) =>
                    return true;
                return false;
