Clear Overlay in mapView
2129
02-10-2017 04:04 PM
RichardDaniels
Occasional Contributor III
I have a tool that gets map coordinates from a mouse click and then does some work. In code add a marker symbol at the location the person clicked. The user may click multiple times prior to exiting the tool. On exiting I would like the overlay to be cleared.
To add the points I'm doing this:
var disposable = await QueuedTask.Run(() =>
return mapView.AddOverlay(myPoint,
SymbolFactory.ConstructPointSymbol(ColorFactory.CreateRGBColor(255,255,0), 10.0, SimpleMarkerStyle.Cross).MakeSymbolReference());
Do I need to keep track of all the disposable vars (perhapse in an array) to do:
disposable.Dispose();
for each maker?
What I would like is a mapView.ClearOverlayAsync() command similar to  the existing
mapView.ClearSketchAsync();.
Ideas?
Rich
CharlesMacleod
Hi Rich, instead use the maptool AddOverlay (and AddOverlayAsync) methods. Any graphics added to the overlay will be disposed when the tool is deactivated.
http://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic9990.html
