Command to find out how fast a layer draws?
1779
6
12-16-2019 06:14 AM
TimWitt2
Hi everybody,
I am trying to implement a window that shows how long it took for each layer, in your map view, to draw. Is there a place in the SDK where I can see this time?
Tim
Tags (1)
MarkChilcott
Occasional Contributor III
Hi Tim,
Are you aware of PerTools - could work for you.
PerfTools for ArcGIS Pro
Cheers,
Mark
MarkChilcott
Hi Tim,
Cheers,
Mark
TimWitt2
This is even better thanks so much Mark.
MarkChilcott
Hi Tim,
There is an equivalent for ArcMap as well.  We use it all the time - has proved very valuable for performance tuning our mxd projects that are published to services.
The scripting also looks interesting - if you are into coding, this could be valuable.
Cheers,
Mark
TimWitt2
Do you know where I can download the ArcGIS Desktop tool?
MarkChilcott
Hi Tim,
The ArcMap equivalent is PerfQAnalyzer.
PerfQAnalyzer
Cheers,
Mark
TimWitt2
Mark this is even better
