Get all edits in a version
1218
10-29-2019 05:05 PM
JimmyBowden
Occasional Contributor II
I'm in need of getting all the features (feature class and oid) that have been edited in a version.  I've seen the example of using a differences cursor ProConcepts Geodatabase · Esri/arcgis-pro-sdk Wiki · GitHub . I'm hoping there's a shortcut in the ArcGIS Pro SDK that prevents me from having to iterate all the feature classes with each difference type.  Any thoughts?  Thanks in advance.
RichRuh
There’s no shortcut. If you’re calling this against a feature service, only one REST call is made.
RichRuh
JimmyBowden
Thanks for the quick response. I still have some concerns about getting the "right" list of feature classes to use but I have enough to work with.  Here's the code I came up with:
using ArcGIS.Core.Data;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Version = ArcGIS.Core.Data.Version;
namespace MyNameSpace
    public class VersionChangesService
        public List<VersionChangesGetChanges(Version version, List<string> featureclassnames)
            List<VersionChanges> retval = new List<VersionChanges>();
            foreach (var item in featureclassnames)
                retval.Add(GetVersionChangesByFeatureClass(versionitem));
            return retval;
        private VersionChanges GetVersionChangesByFeatureClass(Version version, string featureclassname)
            using (Geodatabase versiongdb = version.Connect())
                using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
                    using (FeatureClass defaultFc = geodatabase.OpenDataset<FeatureClass>(featureclassname))
                        using (FeatureClass versionFc = versiongdb.OpenDataset<FeatureClass>(featureclassname))
                            List<VersionChange> diffs = GetAllDifferences(defaultFcversionFc);
                            return new VersionChanges { featureClass = versionFcChanges = diffs };
        private List<VersionChangeGetAllDifferences(FeatureClass defaultFc, FeatureClass versionFc)
            List<VersionChange> retval = new List<VersionChange>();
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.DeleteNoChange));
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.DeleteUpdate));
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.Insert));
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.UpdateDelete));
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.UpdateNoChange));
            retval.AddRange(GetDifferences(defaultFcversionFcDifferenceType.UpdateUpdate));
            return retval;
        private List<VersionChangeGetDifferences(FeatureClass defaultFc, FeatureClass versionFc, DifferenceType differenceType)
            using (DifferenceCursor differenceCursor = versionFc.Differences(defaultFcdifferenceType))
                List<long> diffs = new List<long>();
                while (differenceCursor.MoveNext())
                    using (Row current = differenceCursor.Current)
                        diffs.Add(differenceCursor.ObjectID);
                retval.AddRange(diffs.Select(s => new VersionChange { objectId = sdifferenceType = DifferenceType.DeleteNoChange }));
            return retval;
        public DifferenceType differenceType { getset; }
        public long objectId { getset; }
        public FeatureClass featureClass { getset; }
        public List<VersionChange> Changes { getset; }
