I'm trying to extract the display value of a feature (returned by a selection), but I'm running into a problem when the display field is based off an arcade expression.
When the DisplayField is based on an attribute,I can extract the DisplayField from the CIMFeatureTable and get the display value from the Row, but this does not work when the display field is uses an Arcade expression. I'm able to extract the CIMExpressionInfo, but I cannot "render" it to generate the Display Value.
Is there a way to get the display field value of a feature?
