I am creating an ArcGIS Pro Extension. I need to know the layer's path. To get the layer path, code developed so far:
var pointLayer = MapView.Active.Map.Layers.OfType<FeatureLayer>().FirstOrDefault();
var rasterLayer = MapView.Active.Map.Layers.OfType<RasterLayer>().FirstOrDefault();
var pointLayerPath = await QueuedTask.Run(() => pointLayer.GetPath());
var rasterLayerPath = await QueuedTask.Run(() => rasterLayer.GetPath());
pointLayerPath is assigned the correct path but rasterLayerPath is assigned a null value.
The result is the same for this code also.
MapView.Active.Map.GetLayersAsFlattenedList().OfType<RasterLayer>().FirstOrDefault();
How can I get the RasterLayer path?
