Hi Pascal,
From a FeatureLayer you can get a FeatureClass.
FeatureClass has a method on it called IsJoinedTable. If this method returns true, the feature class is the actual join. At that point, calling FeatureClass.GetName() will return the name of the join.
Unfortunately, there is no Pro SDK routine to remove the join from the layer, but now that you know the name of the join you can use geoprocessing in order to do so.
I hope this helps,
--Rich
