Charlie is correct here are some examples:
MapView.Active.SelectFeatures(MapView.Active.Extent);
or
var selection = MapView.Active.SelectFeatures(clipPoly);
You have to run the SelectFeatures method on the MCT meaning you have to use QueuedTask.Run as in the MapTool sample below:
internal class MapTool1 : MapTool
public MapTool1()
IsSketchTool = true;
SketchType = SketchGeometryType.Polygon;
SketchOutputMode = SketchOutputMode.Map;
protected override Task OnToolActivateAsync(bool active)
return base.OnToolActivateAsync(active);
protected override async Task<bool> OnSketchCompleteAsync(Geometry geometry)
// https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic11992.html
bool result = await QueuedTask.Run(() =>
var selectionSet = MapView.Active.SelectFeatures(geometry);
return true;
return result;
