MoveLayer not working as documented
1446
02-23-2017 05:41 PM
KirkKuykendall
Occasional Contributor III
The documentation for ILayerContainerEdit.MoveLayer says:
The position specified by the 0-based index. If the index is invalid, the layer is moved to the bottom.
However this code doesn't move the layer to the bottom:
 Dim srcLayer = MapView.Active.GetSelectedLayers()(0)
 MapView.Active.Map.MoveLayer(srcLayer, 999)
Only 3 layers are in the map.
Tags (1)
UmaHarano
Hi Kirk,
The MoveLayer method does move the layer to the bottom if you pass in a valid index.
We will look into this!
But in the meantime, this code snippet will help with moving the layer to the bottom:
var srcLayer = MapView.Active.GetSelectedLayers().FirstOrDefault();
            await QueuedTask.Run(() =>
                MapView.Active.Map.MoveLayer(srcLayer, (MapView.Active.Map.Layers.Count - 1));
Thanks!
Uma Harano
ArcGIS Pro SDK Team.
UmaHarano
Hi Kirk,
Thanks!
Uma Harano
