Hi Mehdi Pira,
Here is the code snippet you can use, all in all
1. you need to retrieve feature class list from geodatabase instance, by calling GetDefinitions<FeatureClassDefinition>(), from there just retrieve the feature class name by calling GetName method and compare one by one.
Firstly lets have a view model to keep those result.
public class CatalogSearchResultFeatureClassInfo : NotifyPropertyBase
private string _featureClassName;
public string FeatureClassName
get => _featureClassName;
set
_featureClassName = value;
OnPropertyChanged();
private string _dbConnectionPath;
public string DbConnectionPath
get => _dbConnectionPath;
set
_dbConnectionPath = value;
Next lets implement the search function, this assume user need to select fgdb or sde connection item from catalog.
SearchResult shall be the list of CatalogSearchResultFeaureClassInfo.
All in all read the comment of the process.
private async void PerformSearchFeatureClassCommand(object args)
ArcGIS.Desktop.Core.IProjectWindow currentProjectWindow = Project.GetCatalogPane(true);
if (currentProjectWindow == null)
MessageBox.Show("Please select a geodatabase from catalog");
return;
int selectionCount = currentProjectWindow.SelectionCount;
if (selectionCount <= 0)
return;
this.SelectedConnection = currentProjectWindow.SelectedItems.First();
this._gdbPath = this.SelectedConnection.Path;
Geodatabase geodatabase = null;
Uri gdbPath = new Uri(this._gdbPath);
ProgressorSource ps = new ProgressorSource("Processing search");
List<string> outputFeatureclassNameList = new List<string>();
bool process = await QueuedTask.Run(() =>
if (gdbPath.AbsoluteUri.EndsWith(".gdb", StringComparison.OrdinalIgnoreCase))
geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(gdbPath));
else if (gdbPath.AbsoluteUri.EndsWith(".sde", StringComparison.OrdinalIgnoreCase))
geodatabase = new Geodatabase(new DatabaseConnectionFile(gdbPath));
else
return false;
if (geodatabase == null)
return false;
IReadOnlyList<FeatureClassDefinition> fcd = geodatabase.GetDefinitions<FeatureClassDefinition>();
try
List<string> featureclassList = fcd.Select(x => x.GetName()).ToList();
outputFeatureclassNameList = featureclassList.Where(fcn=> CultureInfo.CurrentCulture.CompareInfo.IndexOf(fcn, this.SearchInput, CompareOptions.IgnoreCase) >= 0).ToList();
catch
return true;
}, ps.Progressor);
if (!process)
ProDialog.MessageBox.Show("Please select a geodatabase from catalog");
return;
this.SearchResult = new List<CatalogSearchResultFeatureClassInfo>();
foreach (string str in outputFeatureclassNameList)
this.SearchResult.Add(new CatalogSearchResultFeatureClassInfo()
DbConnectionPath = this._gdbPath,
FeatureClassName = str
For the add the result item into map, try and bind the searchresult variable to grid or listbox or something , bind with a variable in your viewmodel let say - variable name as SelectedFC,
You can follow this code => LayerFactory.Instance.CreateLayer(new Uri("your feature class path"), map)
Below is the code snippet, which will be helpful for you.
public async void AddToCurrentMap()
var mapView = MapView.Active;
if (mapView != null)
try
string currentFCPath = Path.Combine(this._gdbPath, this.SelectedFC.FeatureClassName);
var ps = new ProgressorSource("Adding the feature class..");
LayerFactory.Instance.CreateLayer(new Uri(currentFCPath), mapView.Map);
}, ps.Progressor);
catch (Exception ex)
MessageBox.Show("Unable to add feature class into map");
else
MessageBox.Show("Please activate a map view to add layer");
return;
