Setting Index of an Attribute
367
12-01-2022 01:35 AM
Meroni
New Contributor III
Hi, is it possible to change the order of attributes in a table? If not, how would I go about cloning a table into a new one, but with reordered attributes?
Aashis
by Esri Contributor
Hi @Meroni
You cannot modify the order of table attributes at the database level, but you can change them at the LAYERS level at any time.
To modify the attributes' order at the database level, we recommend to clone and reorder the original attributes into a new table as
private static void CloneAndReorderFields(Geodatabase geodatabase, TableDefinition oldTableDefinition)
  SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
  // Old table description
  TableDescription oldTableDescription = new TableDescription(oldTableDefinition);
  // Old table's field descriptions
  List<FieldDescription> oldTableFieldDescriptions = new List<FieldDescription>(oldTableDescription.FieldDescriptions);
  // Reordered field descriptions
  List<FieldDescription> reorderedFieldDescriptions = new List<FieldDescription>()
	// Change the order of attribute fields from index 2, 1, 0 (old) to 0, 1, 2 in the new table
	oldTableFieldDescriptions[2], oldTableFieldDescriptions[1], oldTableFieldDescriptions[0]
  // Creating a new reordered table
  TableDescription reorderdTableDescription = new TableDescription($"{oldTableDefinition.GetName()}_Reorder", reorderedFieldDescriptions);
  // Build the new table
  schemaBuilder.Create(reorderdTableDescription);
  bool buildStatus= schemaBuilder.Build();
Aashis
by Esri Contributor
Hi @Meroni
