The user-specified map layer does not exist when opening query table .net sdk
530
6
07-18-2023 03:32 AM
RITASHKOUL
New Contributor III
I am using query definition which contains multiple tables having the join.
var queryDefinition = new QueryDef
      Tables = @"dbo.Table1 table1
      LEFT JOIN dbo.Table2 table2 ON table1.ID = table2.Table1ID
      LEFT JOIN dbo.Table3 table3 ON table2.ID = table3.Table2ID",
      WhereClause = $"table1.Name = {name}"
using var table1Table = table1FeatureLayer.GetTable();
using var database = (Geodatabase)table1Table.GetDatastore();
var queryTableDescription = new QueryTableDescription(queryDefinition);
var queryTable = database.OpenQueryTable(queryTableDescription);
I can have multiple data sources so I am fetching the database from the feature layer present in the required data source.
But when opening the query table I am getting this error:
ArcGIS.Core.Data.Exceptions.GeodatabaseEnterpriseException: 'The user-specified map layer does not exist.'
What is the meaning of this error? I am not able to understand.
@Wolf @UmaHarano @GKmieliauskas  @Aashis
Thanks!
Tags (1)
GKmieliauskas
I think problem is related with query definition string. Have you tried to specify fields directly (without table1, table2, table3)?
RITASHKOUL
New Contributor III
@GKmieliauskas  No I cant do that since I have same name columns in those tables.
GKmieliauskas
I mean write string like below:
      LEFT JOIN dbo.Table2 ON dbo.Table1.ID = dbo.Table2.Table1ID
      LEFT JOIN dbo.Table3 ON dbo.Table2.ID = dbo.Table3.Table2ID",
      WhereClause = $"dbo.Table1.Name = {name}"
Another one thing that "WhereClause" doesn't know about "table1", which is defined in "Tables" string.
RITASHKOUL
New Contributor III
@GKmieliauskas Now I have included the database name as well since without that I am getting table not found. But after adding database name I am getting
ArcGIS.Core.Data.Exceptions.GeodatabaseEnterpriseException: 'The specified attribute column does not exist.'
Even if all the columns mentioned in the sub fields are present in the table.
Tables = @"dbname.dbo.Table1
LEFT JOIN dbname.dbo.Table2 ON dbname.dbo.Table1.ID = dbname.dbo.Table2.Table1ID
LEFT JOIN dbname.dbo.Table3 ON dbname.dbo.Table2.ID = dbname.dbo.Table3.Table2ID",
SubFields = "dbname.dbo.Table1.Id, dbname.dbo.Table1.Name"
GKmieliauskas
Sorry, without database I can't  help you.
Try to comment SubFields and WhereClause properties, then uncomment one by one and check how it works
Aashis
by Esri Contributor
@RITASHKOUL Please refer to the snippets page on setting query defn with Joins.
