I have imported an excel table into ArcGIS Pro and projected it using the X and Y data, and then exported this as a geo database, which I imported into my map. The attribute table contains all of the correct fields, including name, and I can select unique values in symbology to project the layer as I would like. However, under the label tab, none of the fields appear and I cannot add any labels. Does anyone have a solution?
