Show Terms of Use on the ArcGIS Server feature and map service pages
242
12-12-2023 07:33 AM
Status: Open
DavidDodds2
New Contributor II
Users accessing ArcGIS Server services through their browser (https://<host>/<context>/rest/services) can find the copyright text, the description, the service description, and under Document Info: the comments, the subject, and the keywords. However, the "Use limitations" (Pro) or "Terms of Use" (Portal) are not included.
When publishing a REST service using ArcGIS Pro, publishers naturally assume the Use Limitations will be seen by all end-users, regardless of how the data are accessed. We have begun directing our data publishers to add those Terms of Use to the Description as well, in order to ensure all end-users are informed, regardless of how they reach the data.
The data publishers then ask me, "Why do I have to put this same info in two places?" or, "Why is there a Use Limitations section if it doesn't get used?"
I told them, "Good question. I'll ask Esri."
1 Comment
JenniferSmits
I also am interested in this. Specifically, the disparity between the rest service info (description, copyright and spatial reference) and the metadata. Take this open dataset for example, ACT_CANOPY_2020 (FeatureServer) (arcgis.com)
Has all the metadata filled. And its REST: https://actgov.maps.arcgis.com/home/item.html?id=2eb04c29f971499aa3aebe4abaa36059&view=service
The REST has nothing. Firstly, the spatial reference is not correct to the dataset or the metadata, so must be something to do with the original data publishing way back when we used an older coordinate system, but it seems a bit mad that the rest info is not the same as the data and the metadata and document info.
