I've managed to get the create_replica_portal_sample working on my desktop https://github.com/Esri/ArcREST/blob/master/samples/create_replica_portal_item.py
however in production it needs to run on a server through a proxyserver.
All I can get is the error "URLError: <urlopen error Tunnel connection failed: 407 Proxy Authorization Required>"
I suspect the magic should happen by filling in the securityinfo dict in the right way but can someone shine some light on this?
without proxy, on my desktop, it's:
securityinfo{'securitytype':'Portal','username':'myagolusername','password':'myagolpassword'}
I can fill in the proxy_url and proxy_port but that doesn't work. I suspect I need to authenticate myself on the proxyserver.
I did so in another script where I used the form 'http://mynetworkaccount:mynetworkpassword@proxyserver.com:proxyportmynetworkpassword@proxyserver.com:proxyport' but that used urllib2.ProxyHandler and I do not know how to translate that to this case.
Any help, as you all know, is greatly appreciated.
