How can I change the serviceUsername and servicePassword associated with an online feature item that is based on a secure ArcGIS server REST endpoint?
I set the credentials when I create the item:
item_properties={
'title': dp_flc['title'],
'snippet': dp['summary'],
'description': dp_flc['description'],
'tags': dp['tags'].split(','),
'type': 'Feature Service',
'url': service_url,
'serviceUsername': service_user_name,
'servicePassword': service_pw
gis_content_item = AppInfo.gis_agol.content.add(item_properties=item_properties,
data=service_url,
thumbnail=dp_flc['thumbnail'],
folder=AppInfo.content_folder)
But when I include serviceUsername and servicePassword on an update request I get an 'code 500- Error generating token' message. The values username and password values appear to be correct. When I remove the two lines the update works as expected. According to the documentation the 2 parameters are supposed to be supported on update.
# Apply the changes to the feature layer collection
agol_token = row.util.common.get_agol_token (AppInfo.agol_connect_user_name, row.util.stash_credentials.get_password(AppInfo.agol_connect_user_name, 'AGOL'))
params = {'text': json.dumps(update_spec),
'url': dp_rest_service['url'],
'serviceUsername': AppInfo.ags_connect_consumer_user_name,
'servicePassword': row.util.stash_credentials.get_password(AppInfo.ags_connect_consumer_user_name, 'AGS_CONSUMER'),
'f': 'json',
'token': agol_token}
url = AppInfo.agol_connect_host_name + '/sharing/rest/content/users/' + AppInfo.agol_connect_user_name + '/' + gis_content_item['ownerFolder'] + '/items/' + gis_content_item.id + '/update'
req = urllib.request.Request(url, urlencode(params).encode('utf-8'))
response = urllib.request.urlopen(req)
data = json.load(response)
if 'error' in data:
msg = "Feature layer collection update failed: " + str(data['error'])
logger.error (msg)
raise Exception(msg)
