How to query all features from a map service using the exceededTransferLimit parameter?
1292
11-16-2017 08:55 AM
SamuelAbati
New Contributor III
As you can see here : ArcGIS REST API
Near 10.3 they included a new parameters so that you can work with query limits, for example you put a limit on your server of only 1000 records per query and you have 3000 records, you'll have to chain 3 requests.
But how? How can I make asynchronous calls that in a loop using dojo? How can I iterate them in a way that I can return all features
Synchronous mockup :
var query_results = [];var limit_hit = true; #While this is true means that the query hit the record limitvar start_from = 0; #Pagination parameterwhile (limit_hit) {    Server.Query(params={start_from : start_from}, callback=function(result){        limit_hit = result.limit_hit;        start_from = result.results.length;        query_result.push(result.results);    }}
