I'm aware of using arcpy to programmatically create feature classes, but are there other options? I'm interested in a RESTful endpoint specifically.
Hi Andrea,
Using the ArcGIS REST API, you can:
The closest thing to creating a feature class would be creating a service.
If you have access to an ArcGIS server, you could certain host your own custom geoprocessing service to create a feature class using any of the existing arcpy functionality.
I suppose if you publish a geoprocessing service that takes the necessary parameters and creates the featureclass. But why do you want to create the featureclass using a REST endpoint? Perhaps you can elaborate a little more on why you want this...
These sound like good ideas. Thank you. I have a scalable workflow that uses services/capabilities that do not run on the ArcGIS server itself. I'd like to avoid having to write additional code to bridge the gap from one set of servers running in the cloud to reach back to my windows server just to access an arcpy script that creates feature classes. If there already exists a REST endpoint (for example) in ArcGIS for creating feature classes, then I have less work to do and can omit putting a service wrapper around arcpy running on Windows just to expose management type capabilities to my workflow. It doesn't have to be REST, but just some kind of API that I can access remotely. I'll take a look at your suggestions. Thanks
