Hello, I am trying to make an API call to the below endpoint
https://myarcgisserver.mycompany.com/portal/sharing/rest/content/users/myadminuser/createService
When I call this endpoint, I get the below error in an html response
Did you mean /sharing/rest/...?
You are using an unsupported version of this API located at /sharing/. Avoid using and/or developing with this unsupported version. There are pitfalls in doing so and no advantages over using the released and supported version of the API, which is logically equivalent. The supported version is located at /sharing/rest/.
I am seeing the below 2 lines after making this call in the log file on the Enterprise server at C:\inetpub\logs\LogFiles\W3SVC1
2024-01-31 22:45:12 10.0.0.8 POST /portal/sharing/rest/content/users/myadminuser/createService - 443 - 10.0.0.1 python-requests/2.31.0 - 302 0 0 4010
2024-01-31 22:45:12 10.0.0.8 GET /portal/sharing/content/users/myadminuser - 443 - 10.0.0.1 python-requests/2.31.0 - 200 0 0 434
So, it appears the POST method is redirecting (per the 302 HTTP status), but using the /sharing/ path instead of the /sharing/rest path.
Any ideas what would cause this? I have reproduced the issue using PostMan also.
