I am trying to update / add from a python script to ArcGIS feature server with the rets api.
The problem is when I have a null value in a numeric field the server fail. It allow me to use null but not to use “null”. The problem is in python when you build the object to be send to the server you can’t just insert null you have to use the “null”. Python null is None and the server doesn’t get None.
Any ideas ?
