VRP only schedules 360 orders.
359
02-21-2018 12:16 AM
DavidLubinsky
Hi, Just to clarify, the problem with are having is with the Vehicle Routing Problem (VRP) API where it does not schedule more than 360 orders even though the documentation says that the maximum is 2000.
ShubhadaKshirsagar
Hello David,
Are you still facing this?
If yes, do you mean it schedules only 360 orders in one route?
If you see this for each route, there is an attribute called MaxOrderCount in Routes parameter, you might have set that to 360. Do let me know if you still need an answer.
-Shubhada
