For our application we are using ArcGIS Runtime SDK for Android 10.2.9.
In the application, we are able to add KML using KmlLayer.
But when we try get the KmlNode[], near a tapped point,
using the provided getKmlNodes(double x, double y, int tolerance) method,
the application randomly crashes.
We tried using try/catch to catch the error and also tried changing tolerance values.
Also, we have tested in many devices and with different KML files as well.
In Logcat we are getting the following error
"A/libc: Fatal signal 11 (SIGSEGV), code 1, fault addr 0xe9 in tid 25802 (om.ex.test), pid 25802 (com.ex.test)"
2020-09-21 20:17:45.447 8395-8395/com.example.test A/libc: Fatal signal 11 (SIGSEGV), code 1, fault addr 0xe9 in tid 8395 (com.example.test), pid 8395 (com.example.test)
2020-09-21 20:17:45.594 9022-9022/? I/crash_dump32: obtaining output fd from tombstoned, type: kDebuggerdTombstone
2020-09-21 20:17:45.598 852-852/? I
2020-09-21 20:17:45.600 9022-9022/? I/crash_dump32: performing dump of process 8395 (target tid = 8395)
2020-09-21 20:17:45.600 9022-9022/? A/DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
2020-09-21 20:17:45.600 9022-9022/? A/DEBUG: Build fingerprint: 'motorola/athene_f/athene_f:8.1.0/1ec4b:user/release-keys'
2020-09-21 20:17:45.600 9022-9022/? A/DEBUG: Revision: 'p2a0'
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: ABI: 'arm'
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: pid: 8395, tid: 8395, name: com.example.test >>> com.example.test <<<
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0xe9
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: Cause: null pointer dereference
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: r0 00000000 r1 be864f10 r2 be864f00 r3 00000001
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: r4 00000000 r5 41442647 r6 5b1b4b41 r7 41605592
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: r8 8a203900 r9 8a133080 sl 00000005 fp be865030
2020-09-21 20:17:45.601 9022-9022/? A/DEBUG: ip be864f00 sp be864ef8 lr 8437b5d0 pc 843c3e2c cpsr a00f0010
2020-09-21 20:17:45.615 9022-9022/? A/DEBUG: backtrace:
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #00 pc 008bbe2c /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::Map_renderer::World_transform::map_to_display(Esri_runtimecore::Geometry::Point_2D const*, Esri_runtimecore::Geometry::Point_2D*, int) const+28)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #01 pc 008735cc /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::Display_context2d::within_pick(Esri_runtimecore::KML::Point_2d const&, Esri_runtimecore::KML::Icon_display const&)+64)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #02 pc 0086a184 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::Core_layer::test_select_(Esri_runtimecore::KML::Core_node*)+224)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #03 pc 0086a128 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::Core_layer::test_select_(Esri_runtimecore::KML::Core_node*)+132)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #04 pc 0086a128 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::Core_layer::test_select_(Esri_runtimecore::KML::Core_node*)+132)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #05 pc 0086a2d4 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::Core_layer::select_2d(std::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&, double, double, int, int, int)+244)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #06 pc 008428d8 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Esri_runtimecore::KML::KML_layer::select_nodes(Esri_runtimecore::Geometry::Point_2D const&, int, int, int)+212)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #07 pc 00726390 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/lib/arm/libruntimecore_java.so (Java_com_esri_core_internal_map_KmlLayerInternal_nativeSelectNodes+176)
2020-09-21 20:17:45.616 9022-9022/? A/DEBUG: #08 pc 00048595 /data/app/com.example.test-dPnC0d7dY5ma3EEUZ7XRQw==/oat/arm/base.odex (offset 0x3f000)
The backtrace seems to point to the Esri_runtimecore.::KML C++ class.
Is there any workaround for this error?
