Error inflating class com.esri.arcgisruntime.mapping.view.MapView Esri SDK 100.2.1
922
03-18-2018 02:12 PM
FranziskaBlumenschein
I try to run the "get started" project "Develop your fist map" (https://developers.arcgis.com/android/latest/guide/develop-your-first-map-app.htm) but always run into the error:
Caused by: android.view.InflateException: Binary XML file line #0: Binary XML file line #0: Error inflating class com.esri.arcgisruntime.mapping.view.MapView
                   Caused by: android.view.InflateException: Binary XML file line #0: Error inflating class com.esri.arcgisruntime.mapping.view.MapView
                   Caused by: java.lang.reflect.InvocationTargetException
activity_main.xml
<?xml version="1.0" encoding="utf-8"?>
<android.support.constraint.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context="com.esri.arcgisruntime.demos.displaymap.MainActivity">
    <TextView
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:text="Hello World!"
        app:layout_constraintBottom_toBottomOf="parent"
        app:layout_constraintLeft_toLeftOf="parent"
        app:layout_constraintRight_toRightOf="parent"
        app:layout_constraintTop_toTopOf="parent" />
    <com.esri.arcgisruntime.mapping.view.MapView
        android:id="@+id/mapView"
        android:layout_height="match_parent" >
    </com.esri.arcgisruntime.mapping.view.MapView>
</android.support.constraint.ConstraintLayout>
AndroidManifest.xml
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.esri.arcgisruntime.demos.displaymap">
    <application
        android:allowBackup="true"
        android:icon="@mipmap/ic_launcher"
        android:label="@string/app_name"
        android:roundIcon="@mipmap/ic_launcher_round"
        android:supportsRtl="true"
        android:theme="@style/AppTheme">
        <activity android:name=".MainActivity">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
build.gradle (Project)
// Top-level build file where you can add configuration options common to all sub-projects/modules.
buildscript {
    repositories {
        google()
        jcenter()
    dependencies {
        classpath 'com.android.tools.build:gradle:3.0.1'
        // NOTE: Do not place your application dependencies here; they belong
        // in the individual module build.gradle files
allprojects {
    repositories {
        google()
        jcenter()
        // Add the Esri public Bintray Maven repository
        maven {
            url 'https://esri.bintray.com/arcgis'
task clean(type: Delete) {
    delete rootProject.buildDir
build.gradle (app)
apply plugin: 'com.android.application'
android {
    compileSdkVersion 26
    defaultConfig {
        applicationId "com.esri.arcgisruntime"
        minSdkVersion 16
        targetSdkVersion 26
        versionCode 1
        versionName "1.0"
        testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
        ndk {
            abiFilters "armeabi", "armeabi-v7a", "x86", "mips"
    buildTypes {
        release {
            minifyEnabled false
            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
    implementation 'com.esri.arcgisruntime:arcgis-android:100.2.1'
    implementation fileTree(include: ['*.jar'], dir: 'libs')
    implementation 'com.android.support:appcompat-v7:26.1.0'
    implementation 'com.android.support.constraint:constraint-layout:1.0.2'
    testImplementation 'junit:junit:4.12'
    androidTestImplementation 'com.android.support.test:runner:1.0.1'
    androidTestImplementation 'com.android.support.test.espresso:espresso-core:3.0.1'
I try to run it on a Samsung A5 (2017) mobile phone. Is there anything I am missing?
