I am getting a crash trying to get the targetGeometry inside the body of a addViewpointChangedListener.
The crash happens inconsistently but often, looks like a race condition when the map has just been created and the first viewpoint update is somehow not ready to provide the current viewpoint.
Reproduced using arcgis-android version 100.10.0 and 100.11.0 but not 100.6.0.
To reproduce add the viewpoint changed listener to the default 'present map' sample project and try to restart the app a few times:
ArcGISRuntimeEnvironment.setApiKey("YOUR_API_KEY")
val map = ArcGISMap(BasemapStyle.ARCGIS_NAVIGATION)
mapView.map = map
mapView.setViewpoint(Viewpoint(34.0270, -118.8050, 72000.0))
mapView.addViewpointChangedListener { event ->
event.source.getCurrentViewpoint(Viewpoint.Type.CENTER_AND_SCALE)?.let {
viewpoint ->
(viewpoint.targetGeometry as? Point)?.let {
Log.d(TAG, "viewpoint update. Location: ${(GeometryEngine.project(it, SpatialReferences.getWgs84()) as Point)}")
Stacktrace of the exception:
E/AndroidRuntime: FATAL EXCEPTION: main
Process: me.oriient.arcgisplayground, PID: 14075
com.esri.arcgisruntime.ArcGISRuntimeException: Nullability violation: ArcGIS Runtime: 1
Null pointer.
object cannot be null.
at com.esri.arcgisruntime.internal.jni.CoreViewpoint.nativeGetTargetGeometry(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreViewpoint.f(SourceFile:1)
at com.esri.arcgisruntime.mapping.Viewpoint.getTargetGeometry(SourceFile:2)
at me.oriient.arcgisplayground.MainActivity$setupMap$1.viewpointChanged(MainActivity.kt:39)
at com.esri.arcgisruntime.a.i.f.j0$a.run(SourceFile:1)
at android.os.Handler.handleCallback(Handler.java:873)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:6986)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1445)
