Feature services not showing up in Android Map View
2332
01-27-2014 08:10 PM
KrishnaPragada
I have Several Feature Service Layers inside Feature services and when I add Feature services to Map view using following method
ArcGISFeatureLayer secureFeatureLayer = new ArcGISFeatureLayer(Feature_Service_url, MODE.ONDEMAND);
its Layers does not show up in Map view.
But when  I add individual Feature Service Layer  it does show the layer details correctly.
So My question is to add Feature services do I have to add its Layers one by one or is there any other ways to add Feature Service directly to Map view?
RobertBurke
Hi Krishna,
The idea behind an ArcGISFeatureLayer is to work with a single layer at a time.
When defining the Feature_Service_url you have a /1 or /0 at the end. Where that number defines the index position of the desired layer from the FeatureServer.
If you would like to work with all the layers from a service at one time, instead FeatureService, use a MapService.  Also with a map service you wouldn't place the /1 or layer index at the end of the URL.  For this option have a look at ArcGISDynamicMapServiceLayer.
Here is a brief help page describing the variety of layers.
https://developers.arcgis.com/android/guide/map-layer-types.htm
I hope this is helpful.
