How do i create polygon using mapviewhelper ?
1773
8
08-01-2016 04:56 AM
MohamedEzzerI
New Contributor III
This is my code, but not working, is there any thing wrong !?
public void createPolygon() {
        arcMap.addLayer(graphicsLayer);
       String url = "http://.../polygons.json";
        final String resp = StudioUtilities.sendGetRequest(url);
        arcMap.setOnStatusChangedListener(new OnStatusChangedListener() {
        private static final long serialVersionUID = 1L;
        public void onStatusChanged(Object source, STATUS status) {
        try {
                 JSONObject jsonObject = new JSONObject(resp);
                 JSONArray jsonArray = jsonObject.getJSONArray("polygons");
                 int count = 0;
                 while (count < jsonArray.length()) {
                 JSONObject polygon = jsonArray.getJSONObject(count);
                 JSONObject borderObject = polygon.getJSONObject("border");
                 JSONObject startPointObject = polygon.getJSONObject("starting_point");
                 final JSONArray pointsArray = polygon.getJSONArray("points");
                  double[][] p = {
                            33.599389, -7.610728
                            33.599985, -7.597180
                            33.588879, -7.617027
                  int loaded = mvHelper.addPolygonGraphic(p, "pol_t", "pol_st", "", Color.GREEN, Color.DKGRAY, 2, 0);
                  if (loaded < 0) {
                           Toast.makeText(ctx, "Marker Graphic not added to MapView", Toast.LENGTH_SHORT).show();
                  } else {
                           Toast.makeText(ctx, "Marker Graphic is added to MapView", Toast.LENGTH_SHORT).show();
                  count++;
  } catch (JSONException e) {
            e.printStackTrace();
AlexanderNohe1
Occasional Contributor III
Create the color this way:
Color.argb(50, 49, 247, 10)
The first value is the alpha value which is showing 50% transparency.
Therefore, the line would look like this:
int graphic = mapViewHelper.addPolygonGraphic(latLon,"pol_t", "pol_st", "", Color.argb(50, 49, 247, 10), Color.DKGRAY,2, 0);
If this helped resolve the issue, would you kindly select this as the correct answer.
The attached screenshot is what I got below for the above snippet:
AlexanderNohe1
Are you getting any errors or tracebacks when running?
MohamedEzzerI
New Contributor III
No, but i need your help to fill the 2 dimensional array (double[][] p) from the points Array :
polygons: [
    • title: "t_poly1",
    • subtitle: "subt_poly1",
    • background: "green",
    • border: {
      • color: "darkgray",
      • size: 2,
      • style: "solid"
      latitude: "33.6060236",
      longitude: "-7.630058"
      latitude: "33.601975",
      longitude: "-7.632489"
      latitude: "33.605867",
      longitude: "-7.635220"
    • latitude: "33.605626",
    • longitude: "-7.632988"
AlexanderNohe1
Hello Mohamed EzzerI​,
I was able to get the feature to draw in Casablanca using the following snippet:
package com.arcgis.androidsupportcases.addpolygongraphic;
import android.graphics.Color;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.util.Log;
import com.esri.android.map.MapView;
import com.esri.android.map.event.OnStatusChangedListener;
import com.esri.android.toolkit.map.MapViewHelper;
public class MainActivity extends AppCompatActivity {
  MapView mapView;
  @Override protected void onCreate(Bundle savedInstanceState) {
   super.onCreate(savedInstanceState);
   setContentView(R.layout.activity_main);
   mapView = (MapView) findViewById(R.id.map);
   mapView.setOnStatusChangedListener(new OnStatusChangedListener() {
   @Override public void onStatusChanged(Object o, STATUS status) {
   if (status == STATUS.INITIALIZED) {
  MapViewHelper mapViewHelper = new MapViewHelper(mapView);
  double[][] latLon = new double[][] {{
  int graphic = mapViewHelper.addPolygonGraphic(latLon,"pol_t", "pol_st", "", Color.GREEN, Color.DKGRAY,2, 0);
   Log.e("NOHE", "" + graphic);
Here is the screenshot of my end result:
MohamedEzzerI
New Contributor III
^^ , it worked for me, filling the array statically , but what i need is to gather data from the json, if it is possible
MohamedEzzerI
New Contributor III
Thnks Alexander, i hope that you could help me to solve this problem, i already tried to fill the p array using this code, but the app crashes :
double[][] p = new double[2][pointsArray.length()];
int pointCount = 0;
while (pointCount < pointsArray.length()) {
   try {
        final JSONObject point = pointsArray.getJSONObject(pointCount);
        p[0][pointCount] = Double.parseDouble(point.getString("latitude"));
        p[1][pointCount] = Double.parseDouble(point.getString("longitude"));
       pointCount++;
AlexanderNohe1
double[][] p = new double[pointsArray.length()][2];
The points array would be the outside array which would contain the amount of points.  I believe that you have this backwards.  As well as this:
p[pointCount][0] = Double.parseDouble(point.getString("latitude"));
p[pointCount][1] = Double.parseDouble(point.getString("longitude"));
MohamedEzzerI
New Contributor III
Thx a lot, it worked ,
one more issue, is polygon FillStyle, i won't it solid, cuz it covers the map, is there any suggestion
AlexanderNohe1
