I am trying to delete feature from feature layer using apply edits by passing a graphic array as input, but it is showing me the error 'unable to complete operation, no adds,updates or deletes were specified'.
Also, if I am passing the same graphic for update operation then it is being updated successfully.
Following is the code snippet:
Map<String, Object> graphicAttributes = new HashMap<String, Object>();
graphicAttributes.put("OBJECTID", 65);
Graphic mfinalGraphic = new Graphic(null, null, graphicAttributes);
arcGISFeatureLayer.applyEdits(null, new Graphic[]{mfinalGraphic}, null, new CallbackListener<FeatureEditResult[][]>() {
@Override
public void onCallback(final FeatureEditResult[][] featureEditResults) {
runOnUiThread(new Runnable() {
@Override
public void run() {
Toast.makeText(MainActivity.this, "Successfully deleted", Toast.LENGTH_LONG).show();
@Override
public void onError(final Throwable throwable) {
@Override
public void run() {
Toast.makeText(MainActivity.this, "Failed to delete", Toast.LENGTH_LONG).show();
While tracking on fiddler, I am getting the following request:
f=json&deletes=&token=BY26ICX0-KN....
The problem is at rest end if I pass only the object id in f=json&deletes=7&token=BY26ICX0-KN.... then it is getting deleted successfully.
But there is no way of passing only object id in apply edit for delete part in Android API.
Waiting for a positive reply
