InfoTemplate doesn't work when tapped on Graphic
1710
12-27-2011 01:21 PM
SwatiGadey
When I tap on any graphic, it's InfoTemplate doesn't show up. Following is the snippet of code showing how I am creating the Graphic and setting it's parameters.
      * Here, I am getting the results from the QueryTask (in FeatureSet queryResult)
     Graphic graphics[] = queryResult.getGraphics();
     Symbol symbol = new PictureMarkerSymbol(getResources()
      .getDrawable(R.drawable.xyz));
     InfoTemplate infoTemplate = new InfoTemplate("Address",
     (String) graphics[0].getAttributeValue(queryResult
       .getDisplayFieldName()));
     Graphic gr = new Graphic(graphics[0].getGeometry(), symbol, graphics[0].getAttributes(), infoTemplate);
     GraphicsLayer gLayer = new GraphicsLayer();
     gLayer.addGraphic(gr);
If anyone came across this problem or has any suggestion on resolving this issue, please respond to this thread.
Thanks.
ArchanaAgarwal
New Contributor III
Hello,
For the infotemplate information to show please add it to a android view.
Thanks.
SwatiGadey
Do you mean add the information I am providing in my InfoTemplate (includes title and content) to a View object (like a label)?
In case of multiple Graphics, I would like to show the InfoTemplate only upon tapping on that Graphic (instead of a label like view).
Please correct me if my understanding is incorrect. Thanks.
ArchanaAgarwal
New Contributor III
You can use the graphicsLayer.getGraphic(...) method to get the graphic you just tapped on, then show the info template contents in a callout (MapView.getCallout())
map.setOnSingleTapListener(new OnSingleTapListener() {
   @Override
   public void onSingleTap(float x, float y) {
    gl.addGraphic(new Graphic(map.toMapPoint(x,y), new SimpleMarkerSymbol(Color.RED, 15, STYLE.CIRCLE)));
    int[] ids = gl.getGraphicIDs(x, y, 15, 1);
    InfoTemplate infoTemp = new InfoTemplate();
    infoTemp.setContentTemplate("Where is the data ${type}");
    try {
     HashMap<String, Object> attrs = new HashMap<String, Object>();
     attrs.put("type", "Point");
     Graphic gg = new Graphic(map.toMapPoint(x,y),new SimpleMarkerSymbol(Color.YELLOW, 25, STYLE.DIAMOND),attrs, infoTemp);
     gl.addGraphic(gg);
     Log.d(TAG,""+gg.getInfoTemplate().getContent(gg));
     Callout callout = map.getCallout();
     callout.setContent(createContent(ContactInfoTemplate.this, gl.getGraphic(ids[0]).getInfoTemplate(),gg));
     callout.show(map.toMapPoint(x,y));
    } catch (Exception e) {
     // TODO Auto-generated catch block
     e.printStackTrace();
public View createContent(Context context, InfoTemplate info, Graphic gg)
  LinearLayout layout = new LinearLayout(context);
  TextView txt = new TextView(context);
  txt.setText("Content: "+gg.getInfoTemplate().getContent(gg));
  TextView txtAttr = new TextView(context);
  txt.setText("Attr: "+(String)gg.getAttributeValue("type"));
                layout.addView(txt);
  layout.addView(txtAttr);
  return layout;
SwatiGadey
Great! That works.
I appreciate your help.
ArchanaAgarwal
New Contributor III
Awesome!
Its great to hear back from users when stuff works.
