java.lang.NoClassDefFoundError: Failed resolution of: Lcom/esri/arcgisruntime/R$drawable;
2716
11
05-23-2017 05:32 AM
huSkiny
Caused by: android.view.InflateException: Binary XML file line #9: Binary XML file line #9: Error inflating class com.esri.arcgisruntime.mapping.view.MapView
Caused by: android.view.InflateException: Binary XML file line #9: Error inflating class com.esri.arcgisruntime.mapping.view.MapView
Caused by: java.lang.reflect.InvocationTargetException
at java.lang.reflect.Constructor.newInstance0(Native Method)
at java.lang.reflect.Constructor.newInstance(Constructor.java:430)
at android.view.LayoutInflater.createView(LayoutInflater.java:656)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:798)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:738)
at android.view.LayoutInflater.rInflate(LayoutInflater.java:869)
at android.view.LayoutInflater.rInflateChildren(LayoutInflater.java:832)
at android.view.LayoutInflater.inflate(LayoutInflater.java:518)
at android.view.LayoutInflater.inflate(LayoutInflater.java:426)
I am downloaded SDK100.0.0 for android ,and add to lib . I created a xml , but MapView  throw InflateException. So i try to install the SDK that According to the official recommendation,but sync failed again,"Failed to resolve: com.esri.arcgisruntime:arcgis-android:100.0.0".
I will be cry. Who can talk me it is why? thanks.
AlexanderNohe1
Occasional Contributor III
So in your previous post it looks like you have Runtime v 100 installed as well.  Which runtime do you intend to target?  If you are targeting runtime 10.2.x, the mapview XML format is com.esri.android.map.MapView not
as that is a runtime v 100 format.
AlexanderNohe1
Are you storing your layout file in R.layout.my_layout?  Can you upload the XML of the layout you used so I can test on my end?
huSkiny
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:id="@+id/activity_main"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context="com.example.hjy.myapplication.MainActivity">
    <com.esri.arcgisruntime.mapping.view.MapView
        android:id="@+id/mapview"
        android:layout_height="match_parent"/>
</RelativeLayout>
this is  my layout.Thanks for your reply
AlexanderNohe1
Nothing jumps out at me as being off here.  Would you kindly upload the smallest reproducible sample for further inspection on my end?
huSkiny
Hi, Alexander . Thank fot you.
The files(app.rar and build.rar) is the module I created. I install the SDK.  The imge file (download_sdk.png)is downloaded SDK.
I tried many ways, but have no effect .
AlexanderNohe1
For some reason, it does not look like I am able to open any of those zip files.  Do you perhaps have another means of showing me?  Perhaps over GitHub?
huSkiny
Sorry , I forgot the password for GitHub.It has been bothering me for a long time.Here is all my code:
this is mainActivity.java:
public class MainActivity extends AppCompatActivity {
    private MapView mapView;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mapView=(MapView)findViewById(R.id.mapview);
this is module build.gradle:
apply plugin: 'com.android.application'
android {
    compileSdkVersion 25
    buildToolsVersion "25.0.2"
    packagingOptions{
        exclude 'META-INF/LGPL2.1'
        exclude 'META-INF/LICENSE'
        exclude 'META-INF/NOTICE'
    defaultConfig {
        applicationId "com.example.hjy.testmapview"
        minSdkVersion 15
        targetSdkVersion 25
        versionCode 1
        versionName "1.0"
        testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
        vectorDrawables.useSupportLibrary = true
    buildTypes {
        release {
            minifyEnabled false
            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
//    sourceSets {
//        main {
//            jniLibs.srcDirs = ['libs']
dependencies {
    compile fileTree(include: ['*.jar'], dir: 'libs')
    compile 'com.android.support:appcompat-v7:25.3.1'
    compile 'com.android.support:design:25.3.1'
    compile 'com.android.support:support-vector-drawable:25.3.1'
    compile 'com.esri.arcgis.android:arcgis-android:10.2.8'
//    compile files('libs/arcgis-android-api.jar')
//    compile files('libs/gson-2.3.1.jar')
this is project build.gradle:
buildscript {
    repositories {
        jcenter()
    dependencies {
        classpath 'com.android.tools.build:gradle:2.3.2'
        // NOTE: Do not place your application dependencies here; they belong
        // in the individual module build.gradle files
allprojects {
    repositories {
        jcenter()
        maven {
            url 'http://dl.bintray.com/esri/arcgis'
task clean(type: Delete) {
    delete rootProject.buildDir
this is main.xml:
    xmlns:app="http://schemas.android.com/apk/res-auto"
    android:id="@+id/container"
    tools:context="com.example.hjy.testmapview.MainActivity">
</RelativeLayout>
AlexanderNohe1
huSkiny
Oh , my god ! I sorry ,I just think it is same of  the Mapview. I think i should take a break。haha~
AlexanderNohe1
Yeah, it can kind of be tricky when moving from the old runtime to the new runtime.  Glad that we were able to get this cleared up.  Would you kindly mark the correct answer?
Alexander
