Javadoc for ArcGIS Runtime SDK for Android Version 10.1.1
3509
14
02-26-2013 12:46 PM
ViridianaGO
New Contributor III
Hello, thanks for read me. I upgrade my ArcGIS Runtime SDK for Android to Version 10.1.1; everythinks works fine and I don´t have any problem with my project, but now I can´t see the Javadoc; when I put the cursor over the text this message appears:
"Note: This element has no attached source and the Javadoc could not be found in the attached Javadoc."
I intented to change the Javadoc location in Java Build Path, but when I selected the item it can not be edited. I attach the image. How can I see the documentation again?
Thanks for your help.
PabloStorniolo
Hello, I have the same problem.
My system:
win 7 x64 SP1
Eclipse 4.2.1
deleted-user-ATjHIWsdQYmT
Same here - no Javadoc...
I've tried all the above and still can't get it to work.  Has anyobody?
I'm running Elipse 3.6
DanO_Neill
Occasional Contributor III
We have reproduced the issue of only classes showing up on javadoc hover in Eclipse.  I am looking into the issue and will provide an update soon.
DanO_Neill
The fix will be in our upcoming v10.2 release.
MartinRick
Is fixed now.
Thank you!
Martin
