I am using
com.esri.arcgisruntime:arcgis-android:100.9.0
In our project we have other libraries that are using ndk code. This code is https://voicelayer.io library. I had compile issues that were solved by adding to Gradle:
packagingOptions {
pickFirst "**/libc++_shared.so"
sourceSets {
main {
jniLibs.srcDirs 'src/main/cpp/libs'
However, thaw project compiles, during runtime MapView is blank. There is runtime error:
Fatal Exception: java.lang.UnsatisfiedLinkError
dlopen failed: cannot locate symbol "_ZTISt12bad_any_cast" referenced by "/data/app/~~uUhKQILyWGcrKBnY0Jt6ag==/com.snap.android.apis.dev-QExIXjmVL_fg0C3XYZJrIQ==/base.apk!/lib/x86/libruntimecore.so"...
com.esri.arcgisruntime.ArcGISRuntimeEnvironment.a (SourceFile:230)
com.esri.arcgisruntime.ArcGISRuntimeEnvironment.initialize (SourceFile:204)
com.esri.arcgisruntime.internal.jni.CoreMap.<clinit> (SourceFile:49)
com.esri.arcgisruntime.mapping.ArcGISMap.<init> (SourceFile:370)
....MainActivity.onCreate (MainActivity.kt:295)
I've tried to work around it any possible way, by removing libraries from project and test it over and over again. I could not find the source of the problem.
I've created a sample project with the exact same libraries in Gradle and MapView shown as expected.
I suspect that in the original project we actually load and use the third party NDK before we use the ESRI MapView and maybe that cause the problem.
I assume having ESRI deployed side by side with other libraries that are using NDK is common and I was surprised ESRI Documentation skipped this possibility.
You can find below a copy of the Gradle.
Thank you in advance for any assistance.
Best regards,
Gabriel
Gabriel.Noam@Cognyte.com
apply plugin: 'com.android.application'
apply plugin: 'kotlin-android'
apply plugin: 'kotlin-android-extensions'
apply plugin: 'kotlin-kapt'
apply plugin: 'com.google.firebase.crashlytics'
android {
compileSdkVersion 29
buildToolsVersion '29.0.3'
defaultConfig {
applicationId "....."
minSdkVersion 23
targetSdkVersion 29
versionCode 507100001
versionName "5.7.100.001"
ndk {
abiFilters "armeabi", "armeabi-v7a", "arm64-v8a", "x86", "x86_64"
testInstrumentationRunner 'androidx.test.runner.AndroidJUnitRunner'
kotlinOptions {
jvmTarget = '1.8'
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
javaCompileOptions {
annotationProcessorOptions {
arguments += [
"room.schemaLocation":"$projectDir/schemas".toString(),
"room.incremental":"true",
"room.expandProjection":"true"]
buildTypes {
debug {
minifyEnabled false
debuggable true
release {
debuggable false
// Cannot minifyEnabled true, causes runtime exceptions
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
flavorDimensions "version"
productFlavors {
dev {
applicationIdSuffix ".dev"
dimension "version"
stable {
applicationIdSuffix ".stable"
dimension "version"
prod {
dimension "version"
/**** SIGNING CONFIG HERE ***/
lintOptions {
abortOnError true
packagingOptions {
sourceSets {
main {
buildFeatures{
dataBinding = true
viewBinding = true
compileOptions {
testOptions {
unitTests.includeAndroidResources = true
// StampBuild - generate a file with the build date as constant.
task markVersion(type: Exec) {
commandLine('pwd')
commandLine "python", "../../tools/stampBuild.py", "${defaultConfig.applicationId}"
task checkDebugDelinquency(type: Exec) {
logging.captureStandardOutput LogLevel.WARN
commandLine "python", "../../tools/checkDelinquentBuild.py", "${defaultConfig.applicationId}"
preBuild.dependsOn markVersion, checkDebugDelinquency
repositories {
maven { url 'https://raw.github.com/applanga/sdk-android/master/maven/releases/'}
maven { url 'https://jitpack.io' }
dependencies {
implementation fileTree(include: ['*.jar'], dir: 'libs')
implementation fileTree(dir: 'libs', include: ['*.jar'])
//noinspection GradleDynamicVersion
implementation 'com.opentok.android:opentok-android-sdk:2.16.4'
implementation('io.socket:socket.io-client:1.0.0') {
// excluding org.json which is provided by Android
exclude group: 'org.json', module: 'json'
//implementation 'androidx.legacy:legacy-support-v4:1.0.0'
implementation 'androidx.exifinterface:exifinterface:1.3.0'
implementation "androidx.appcompat:appcompat:$appcompat_version"
implementation "androidx.constraintlayout:constraintlayout:$constraintlayout_version"
implementation "androidx.vectordrawable:vectordrawable:$vectordrawable_version"
//noinspection GradleDependency,GradleDynamicVersion
//implementation 'io.intercom.android:intercom-sdk-base:6.+'
implementation "com.google.guava:guava:$guava_version"
implementation "com.google.protobuf:protobuf-java:$protobuf_version"
//AppLanga
implementation "com.applanga.android:Applanga:$applanga_version"
// Lock pattern
// implementation 'com.bcgdv.asia.lib:connectpattern:0.3'
// PTT
//implementation 'com.skyfishjy.ripplebackground:library:1.0.1'
implementation 'io.jsonwebtoken:jjwt:0.9.1'
implementation "com.squareup.okhttp3:okhttp:$okhttp3_version"
implementation "com.google.code.gson:gson:$gson_version"
// Misc
implementation 'jp.wasabeef:richeditor-android:1.2.2'
implementation "org.jetbrains.kotlin:kotlin-stdlib-jdk7:$kotlin_version"
implementation "org.jetbrains.kotlin:kotlin-reflect:$kotlin_version"
implementation "org.jetbrains.kotlinx:kotlinx-coroutines-android:$kotlin_coroutine_version"
implementation 'com.squareup.picasso:picasso:2.71828'
// EddyStone
implementation 'com.neovisionaries:nv-bluetooth:1.8'
// Barcode scanner
// implementation 'com.journeyapps:zxing-android-embedded:3.6.0'
// ESRI
implementation "androidx.browser:browser:1.0.0"
implementation "com.esri.arcgisruntime:arcgis-android:$esri_version"
//implementation (name: 'arcgis-android-100.9.0', ext: 'aar')
// Testing
testImplementation 'junit:junit:4.13.1'
testImplementation 'com.google.truth:truth:1.0'
testImplementation 'androidx.test:core:1.3.0'
testImplementation 'org.mockito:mockito-core:3.1.0'
// Testfairy
debugImplementation 'testfairy:testfairy-android-sdk:1.+@aar'
// timber v4
implementation "com.jakewharton.timber:timber:$timber_version"
implementation "androidx.media:media:$media_version"
implementation "androidx.fragment:fragment-ktx:$fragment_ktx_version"
implementation "com.google.android.material:material:$material_version"
implementation "androidx.recyclerview:recyclerview:$recyclerview_version"
implementation "org.koin:koin-androidx-scope:$koin_version"
implementation "org.koin:koin-androidx-viewmodel:$koin_version"
implementation "org.koin:koin-androidx-fragment:$koin_version"
// Firebase
api "com.google.firebase:firebase-messaging:$firebase_messaging_version"
implementation "com.firebase:firebase-jobdispatcher:$firebase_jobdispatcher_version"
api "com.google.firebase:firebase-core:$firebase_core_version"
api "com.google.firebase:firebase-analytics:$firebase_version"
// Import the BoM for the Firebase platform
api platform("com.google.firebase:firebase-bom:$firebase_bom_version")
// When using the BoM, don't need to specify versions in Firebase library dependencies
implementation 'com.google.firebase:firebase-crashlytics-ktx'
implementation 'com.google.firebase:firebase-analytics-ktx'
implementation "androidx.work:work-runtime-ktx:$work_version"
implementation "com.github.bumptech.glide:glide:$glide_version"
kapt "com.github.bumptech.glide:compiler:$glide_version"
implementation "com.squareup.retrofit:retrofit:$retrofit_version"
implementation "com.squareup.retrofit:converter-gson:$retrofit_version"
implementation "com.squareup.retrofit2:retrofit:$retrofit2_version"
implementation "com.squareup.retrofit2:converter-gson:$retrofit2_version"
implementation "com.squareup.retrofit2:converter-jackson:$retrofit2_version"
implementation "com.squareup.retrofit2:converter-scalars:$retrofit2_version"
implementation "com.google.android.gms:play-services-analytics:$play_services_analytics_version"
implementation "com.google.android.gms:play-services-gcm:$play_services_gcm_version"
implementation "com.google.android.gms:play-services-maps:$play_services_maps_version"
implementation "com.google.android.gms:play-services-location:$play_services_location_version"
implementation "androidx.room:room-ktx:$room_version"
implementation "androidx.room:room-runtime:$room_version"
testImplementation "androidx.room:room-testing:$room_version"
kapt "androidx.room:room-compiler:$room_version"
implementation "androidx.lifecycle:lifecycle-livedata-ktx:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-viewmodel-ktx:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-runtime-ktx:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-reactivestreams-ktx:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-service:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-process:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-extensions:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-viewmodel-savedstate:$lifecycle_version"
implementation "androidx.lifecycle:lifecycle-common-java8:$lifecycle_version"
//noinspection LifecycleAnnotationProcessorWithJava8
kapt "androidx.lifecycle:lifecycle-compiler:$lifecycle_version"
kapt "com.android.databinding:compiler:$databinding_compiler_version"
implementation project(path: ':fliclib')
implementation project(path: ':viziblezone')
implementation project(':voicelayersdk')
buildscript {
repositories {
maven {
jcenter()
dependencies {
classpath "com.applanga.android:plugin:$applanga_version"
apply plugin: 'com.google.gms.google-services'
buildscript {
ext.gradle_version = '4.2.0-beta01'
ext.kotlin_version = '1.4.10'
ext.kotlin_coroutine_version = '1.3.6'
ext.applanga_version = '3.0.132'
ext.gson_version = '2.8.5'
ext.appcompat_version = '1.2.0'
ext.core_ktx_version = '1.3.2'
ext.constraintlayout_version = '2.0.2'
ext.material_version = '1.2.1'
ext.lifecycle_version = "2.2.0"
ext.google_services_version = '4.3.4'
ext.crashlytics_gradle_version = '2.4.1'
ext.realm_version = '6.0.2'
ext.protobuf_version = '3.11.0'
ext.okhttp3_version = '4.2.2'
ext.recyclerview_version = '1.1.0'
ext.room_version = '2.2.5'
ext.play_services_gcm_version = "17.0.0"
ext.play_services_maps_version = "17.0.0"
ext.play_services_location_version = "17.1.0"
ext.play_services_analytics_version = "17.0.0"
ext.retrofit_version = "2.0.0-beta2"
ext.retrofit2_version = "2.9.0"
ext.glide_version = "4.11.0"
ext.work_version = "2.4.0"
ext.fragment_ktx_version = '1.2.5'
ext.databinding_compiler_version = '3.1.4'
ext.firebase_messaging_version = '21.0.0'
ext.media_version = '1.2.0'
ext.vectordrawable_version = '1.1.0'
ext.guava_version = '27.0.1-android'
ext.koin_version = '2.2.0-alpha-1'
ext.timber_version = '4.7.1'
ext.firebase_bom_version = "26.1.0"
ext.firebase_version = "18.0.0"
ext.firebase_core_version = "18.0.0"
ext.firebase_crashlytics_version = "17.3.0"
ext.firebase_jobdispatcher_version = "0.8.5"
ext.esri_version = "100.9.0"
repositories {
jcenter()
google()
maven {
url 'https://dl.bintray.com/intercom/intercom-maven'
dependencies {
classpath "io.realm:realm-gradle-plugin:$realm_version"
classpath "com.android.tools.build:gradle:$gradle_version"
classpath "com.google.gms:google-services:$google_services_version"
classpath "org.jetbrains.kotlin:kotlin-gradle-plugin:$kotlin_version"
classpath "org.jetbrains.kotlin:kotlin-serialization:$kotlin_version"
classpath "com.google.firebase:firebase-crashlytics-gradle:$crashlytics_gradle_version"
allprojects {
repositories {
jcenter()
maven {
url 'https://esri.jfrog.io/artifactory/arcgis'
maven {
url 'https://tokbox.bintray.com/maven'
maven {
url "https://maven.google.com"
maven {
flatDir {
dirs 'libs', '../viziblezone/libs'
google()
