I've been working on a map that places PictureMarkerSymbols with custom drawables, and I've noticed that the PictureMarkerSymbols are blurry when displayed on the map.
I've tried the following:
The my location (blue dot) icon is very crisp. How do you achieve this.
Note: after more testing, I've noticed the blurriness is more pronounced with a LayerDrawable. Could this be the source of my issue?
Do you have the picture that you are trying to use available for us to test with?
After more testing, I'm 99% certain it's the fact that I was using a LayerDrawable. For some reason, PictureMarkerSymbol doesn't scale these correctly. For testing, it should produce this effect for any LayerDrawable (or xml drawable <layer-list>)
Hey Jeff,
After testing this offline for a little bit, I believe that this might be a suitable workaround for you. I believe that if you store the image as an asset and then create it as a drawable at Runtime, you will get better results with the display of the image.
new PictureMarkerSymbol(Drawable.createFromStream(getAssets().open("Shell-Red-Icon.png"), null))
I look forward to seeing how this works for you.
Upon even further testing, I think I have some evidence that helps show the difference between loading the image in as a drawable image asset and just as an asset. Using the code snippet above, the difference is noticable for the red shell icon. What do you think?
Loading as a drawable, the shell looks blurry:
Loading as an asset, the shell looks clear:
That did not do the trick for me unfortunately. Both loading from drawables and loading from assets have the same amount of blurriness, at least to the naked eye. I may be wrong, and feel free to correct me if I am, but I think I may know why you saw improvements in your example. If you use drawables and the PictureMarker(Drawable)
constructor (not PictureMarkerSymbol(Context, Drawable)
), it will not resize the drawable. For some reason, using Drawable.createFromStream()
does resize it. It looks like to me that loading from assets, and using the PictureMarkerSymbol(Context, Drawable) constructor accomplishes the same thing
For anyone who comes across this later, my biggest issue was using `LayerDrawable`. To solve this problem, I just put multiple graphics on the screen to imitate one drawable with many layers
That looks promising, I'll try it out and report back. Thanks!
I have the same problem, but in a Web Application. Can any one help me with this issue. I am developing a Web Application with ArcGIs API Javascript that was working with Google API. You can notice the diference between the Original Image and the same image that was opened over the map using PictureMarkerSymbol
Original Image
Web Application using Google API
NEW Web Application using ArcGis API Javascript
