Vector basemap in runtime SDK
1023
12-21-2016 05:34 AM
JasonChristian
I am planning to use an offline vector basemap for an android app. Here's where I found the information
Vector tile layers—ArcGIS Online Help | ArcGIS
It says that the support for Runtime SDKs will be available on 2017, but the page in German language says that it is supported in 2016.
If it is already supported in Android's runtime SDK,  can anyone tell me on:
  1. How to make the vector basemap files? What are the extensions of the file? Can it be produced using Android's ArcGIS Desktop Pro?
  2. Where do I put the files ? inside the SDcard or can it be accessible inside android's asset / raw folder?
  3. How can I access it and apply it to the map using Android's runtime SDK?
It'll be great if there's a tutorial or a sample code on how to do them.
Thank you
nita14
HI Jason,
1) Use ArcGIS Pro to create .vtpk  file. Check this Author a map for vector tile creation—ArcGIS Pro | ArcGIS for Desktop
2) Rather SD Card. Grant permissions to acces external storage in you Android Studio project
3) Here is the reference: ArcGISVectorTiledLayer| arcgis-android
Check also the samples: ArcGIS Runtime SDK for Android | ArcGIS for Developers
Hope this helps,
Adam
nita14
HI Jason,
Hope this helps,
Adam
