About 100.2 and 100.6
399
02-18-2020 02:13 AM
TakahiroKAMIYA
Is there any difference in the rendering of the map when using mmpk file in 100.2 and 100.6?
Is the following perception wrong?
100.2 displays map data in a range not displayed on the terminal screen (it develops the data on the memory).
On the other hand, in 100.6, the range that is not displayed on the terminal screen is not it develops the data on the memory, so if you move the map, the map will be redrawn frequently, so it may be a jerky movement.
