addFeature vs. updateFeature
399
01-08-2019 03:51 PM
MichaelDavis3
I'm updating some apps from runtime 2.5 to 100.4
It looks like the AGSGDBFeatureTable saveFeature method has been replaced by the AGSGeodatabaseFeatureTable addFeature and updateFeature methods.
Do I need to detect if the feature is "new" and use the appropriate add or update method now?
SuganyaBaskaran1
That is correct. For new features, you would first create a feature using one of the create methods on AGSGeodatabaseFeatureTable. Once created, you can add the feature to the table using the add method.
For existing features, you typically get a reference to the feature first (query, identify etc), edit and call the update method.
Hope that helps.
SuganyaBaskaran1
Hope that helps.
MichaelDavis3
Thanks - I have tons of generic edit views where I might have either a new or existing feature that is being edited.  Previously the saveFeature method worked fine for either, but I guess I'll have to use AGSGeodatabaseFeatureTable's canUpdateFeature to check if it is new (not updatable) or not and take the appropriate route.
Am I assuming correctly that a new feature will return a NO when I check with canUpdateFeature?
SuganyaBaskaran1
Yes, it would. A feature created just exists in memory whereas an update operation is done on the table. canUpdateFeature would return true after you've added the feature to the table using add method.
