Thank you for your question! The `minScore` property on `AGSGeocodeParameters` is for offline geocoding only. For online geocoding, `minScore` has no effect. The default value is 0.
A couple of quick tips: The `AGSGeocodeResult` object has a `score` property, so you don't need to access the attributes to get at the score:
print("result score = \(result.score)")
Also, if you want to filter results based on the minScore, you can do this:
let filteredResults = results.filter { $0.score >= params.minScore }
I will get the doc updated to avoid future confusion.
If you have any more questions, let us know!
Mark
